Mountain Hard Tail
Mountain Hard Tail
Dogo
I´ve been looking for my perfect bike and here you´re. I´ve change, and change and, finally, this is my fourth bike but now it has all that I need. I change the suspension fork into a Marzocchi and I also change the brakes, now it wears a pair of Avid´s and they are perfect. In my opinion it´s the one of the most beautiful bikes I ever seen... of course... it´s mine.
steady-eddy
Drubix
All original except tires, grips, possibly the stem and handle bar, but still have orginal bar. More pics to follow. Serial#22001890024
Yarg
Got her Sept 2010 in a sorry state tracked age and model from serial no,s have repainted and rebuilt her with a lefty fork and a rear disc modification that works brilliantly all home made,have given her a test run and is luvly jubly lol...
I´ve changed my 2010 Merida TFS100D XC for this beauty, and the diference is awesome. Bike check: F800 SL CAAD5 Fatty Ultra Hubs:rear Magura PRO with titanium Kore quick release,front Echo with sealed bearings Wheels: Mavic 223 disc only Tires: Hutchinson Acrobat 1.95 Gripshift,front and rear derraileur:SRAM X9 Chain:SRAM PC-971 Rear cogs:shimano SLX Brakes:Shimano XT Disc Brake: Avid G2CS Stem:Truvativ AKA oversize Handlebar:Ritchey comp Seatpost: Ritchey Pro Crankset:Truvativ Firex with...
About a month ago I was searching craigslist for a bicycle and I cam across this Cannondale up it needed some upgrades Following: Wheelset:Shimano Shifters: Shimano Rapid-fire 8speed Crankset: Shimano Deore LX Cassette: Shimano 8speed Derailleurs:Shimano Alivio RIDE'S LIKE A DREAM NOW
Elvis
I got this for less than the cost of a decent tire, coming home early after being dropped on a road ride. Sometimes being slow is good... I passed by a street where people were getting ready for a fleamarket, and bam, this thing was being unloaded. It was easy to set it up, as it had little damage -- a rusty chain and a cracked front grip shift were the big issues. I lubed the chain (will replace soon) threw in a pair of Suntour XCM thumb levers to replace the cracked grip shift, and ran...
DIMA
Fork : Fatty DL Wheels : Mavic Crossmax SLR Tires : Schwalbe NN/RR Pedals : Shimano M970 XTR Cranks : Shimano XTR Chainset M970 44/32/22 Chain : SRAM PC991 Rear Cogs : XTR M970 11-32 Front Derailleur : XTR M971 Rear Derailleur : SRAM X-0 Medium Cage Shifters : SRAM X-0 SRAM X-9SL Twister Shifter Handlebars : Easton Riser EC90 MonkeyLite CNT Carbon Grips : Titec Pluto Pork Stem : Headshok Stem 120mm 5 Deg 31.8 Headset : Cannondale HeadShok Si Brakeset Formula R-1 Saddle : Selle Italia...
jfr1980
1K
Cuadro: CANNONDALE F300 CAAD2 Horquilla: Recon Race 100mm (2010) Dirección: Cane Creek XX c|| Manillar: Ritchey PRO Potencia: Ritchey PRO Puños: Coda Acoples: Ritchey WCS Tapones para manillar: Hope Cierre tija sillin: Hope Tija sillín: Cannondale - A la espera: Ritchey WCS Sillín: Cannondale Maneta de freno izquierda: Shimano Deore XT Disc 160mm Maneta de freno derecha: Avid Speed Dial 7 / Shimano Deore XT V-brake Llantas + bujes: Mavic Crossland BLACK UST TUBELESS Neumático delantero: IRC...
UPDATE: now i've coated the frame and got a set of white Suntour forks to match
ebabiker
More about my bike on http://www.ebaweb.nl/bike/bike.html
ariesboy
3K
Hey Guys, Just wanted to share my latest build with you and to say thanks for answering my questions over the last several months while building this bike. I have learned so much just by building this bike. Building a WW bike is definitely a great challenge! This bike is a rocket! It accelerates like my road-bike but can take on the rough stuff with no problems! While some parts are a bit controversial (nobu shifters), I do not race and will just use the bike for cross training rides...
ebbor
Specifications : Frame : Alu polished 17\" handle bars: Cannondale coda shifters/brakes: Shimano Deore XT pads: Shimano Deore XT forks: pepperoni fork front derailleur: Shimano Deore LX chainrings: Race Face 44/32/22 crank: Shimano STX pedals: ? rear derailleurs: Shimano Deore XT rim front: Mavic 317 hub front: Shimano LX tire front: Maxiss larssen 2.0 rim rear: mavic 317 hub rear: Shimano LX tire rear: Maxiss larssen 2.0
