Another one of my projects... This time a Cannondale Jekyll.
The frame I picked up in Germany in 2008, and it was completely unused. I suspect that the frame is either a warranty replacement or possibly a Jekyll 600 Frame set as there are no model numbers on the frame.
It originally came with the bonded aluminium rear swing arm, which I wouldn't trust for fear of breakage. They bonded swing arm was notorious for failure, so I replace the rear end with the welded version (hence the raw...
Log in or register now.
