John Simpson
I have a 1986 Cannondale SR500 touring bike. I have upgraded the shifter cables, brake/shifter levers, rims/wheels, and derailleurs and as a final upgrade I would like to replace the bottom bracket bearing assembly. Any advice as a compatible sealed bottom bracket bearing assembly that would fit the threads and also integrate with the original crank arms (with the square holes) for this bike? I would consider replacing the cranks if need be to allow the more modern bottom bracket to be utilized.
Thank you,
John
Thank you,
John
