rickpaulos
62cm May 06 1991? Seems to be missing a leading zero on the month.
Had a Schwinn Varsity front wheel.. replaced with a light road wheel. The seat post bolt was buggered. I think the hex socket was stripped out and partially drilled out. Stuck "open" not tight enough to hold the seat post so they added some inch sheet metal screws to hold the post in place. We finished drilling out the damaged bolt and removed the stray screws. All good now. Needs a top tube cable clip. 2 prong plug in style. Small ring was removed. The chain was jammed in the bb when we got it.
Cannondale.green (2) by rickpaulos, on Flickr
Cannondale.serial.number (1) by rickpaulos, on Flickr
Cannondale.62506915698 (4) by rickpaulos, on Flickr
