2002 F800 Coda Crank Question
skyclean
Hey all,
I was hoping a forum member would be able to answer the following question.
I have a 2002 Cannondale F800 & have a set of black coda crank arms that requires a shimano Octalink v1 bottom bracket. Question is would a 68 x 109.5 have enough frame clearance etc? If not what would be the correct axle width? 112.5?
Many thanks
Sheldon Brown lists most V1 Shimano triple cranks as needing 112-118.5 mm spindles. I would expect a 109.5 to be too narrow, though I don't know where to find specs for Coda. I have a few Coda triples but I think they are all square taper. Will check. I think it would be safest to go with the 116 or 118.5 spindles if we can't nail down exactly what the Coda cranks used.
