I'm currently breaking down a 1998 Super V 2000 to powder coat it. I'm having trouble removing the pivot bolt. I believe it to be the gold 3 piece A459 pivot bolt. I've tried WD40 and PB Blaster to help loosen it up. I've been using two 8mm allen wrenches (turning counter-clockwise) with a breaker bar and ratchet on the other. So far the bolt has not broken loose. Any tricks or tips to get this to break loose?
Thanks,
David
Thanks,
David
