How much is my f700 worth ? 2002
Buddman66
Buddman66
Dt Swiss centre lock rear wheel + brand new wide front wheel / 700c x 28 front / 700c x 35 rear
Buddman66
This bike really hasn’t been used too much as the grips are hardly worn original ones and bike did still come with one original hutcherson tyre but replaced 1 tyre with panneracer 2.1 rear
Buddman66
Thanks for the response , 35 won’t fit the front due to clearance and the valve cap on headshok , I needed some orange touch up paint for the fork as it has slight mark on top of fork and lower side of fork . I have noticed that it seems to have sun fade on outer fork on both sides but it’s ok on the inner fork . I’m guessing it’s sun fade
Buddman66
Any idea where I can get the correct paint would be very helpful , I’m in the Uk
For some touch up work I would try to mix some yellow and orange. It will take some experimenting but I would think you can get it pretty close. I think I have some 1997 Mango which would be close but you can probably come up with something just as good mixing model car paint.
Buddman66
I’m going to go a motor factors and just try my best . I’ve posted another topic about my 700c wheels if you had any ideas would be great . It’s listed under dt Swiss centre lock
